Discussion topic: No signal
Message posted on 05 Aug 2025 02:18 PM
No signal
Message posted on 05 Aug 2025 02:24 PM
Re: No signal
@LWood
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
