Discussion topic: No signal
This message was authored by: Hullyboi1
No signal
Hi I'm constantly getting isssue with my sky a box loosing signal I've reset the box multiple times check all the connections and no joy this happens every few days then resolves its self we live in a apartment block so communal dish
Sky Q 1 TB
Re: No signal
@Hullyboi1
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish).
