Discussion topic: No signal
This message was authored by: Tracyw
No signal
I am trying to speak to a rep  we have done the all the checks we xan
Re: No signal
@Tracyw
No signal or no satellite signal?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
