Discussion topic: No signal
This message was authored by: DavidN10
No signal
Sky multi room box no signaling
Re: No signal
Hi @DavidN10
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
