Discussion topic: No signal
This message was authored by: lisa2013
No signal
Hi I carnt get any single on my tv
Re: No signal
@lisa2013
No signal or no satellite signal? They are totally different
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE ▪️
