Discussion topic: No signal
Message posted on 12 Sep 2024 08:06 PM
No signal
Hi, was told I had to upgrade to Sky Q.
it's never really worked.
3-4 nights is ok, rest - no signal.
cant even watch free view as all through your connection.
want to swap out if this cant be fixed.
never had issue before.
engineer said some Chanel's may not work - why? And now have none at all.
Message posted on 12 Sep 2024 08:13 PM
Re: No signal
want to swap out if this cant be fixed.never had issue before.
Hi @27
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
