Discussion topic: No signal
This message was authored by: Kerry19
No signal
2 red lights on box can get it to switch back on
Re: No signal
Hi @Kerry19   What happens if you press the on/off switch on the box (on the right).
Avatar for Kerry19
Re: No signal
No buttons work at all even the reset button
Re: No signal
@Kerry19 i'm guessing this is yourmain Q box try unplugging the box from the socket for 15 minutes then plugging it back in
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
