Discussion topic: No signal
This message was authored by: JoCrawshaw
No signal
My second sky q mini box shows no signal on tv however tv is connected to the internet. Cable is plugged in.
Re: No signal
@JoCrawshaw
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Avatar for JoCrawshaw
Level 0 icon
Re: No signal
Yes it's no satellite signal. It used to work fine. My main box in the lounge works fine. It then says select source which I have and is all set up fine.
Re: No signal
@JoCrawshaw
If it is only showing no satellite signal on the mini box, then;
on your main Sky Q box go to Settings > Watch on Sky Q Mini Box > Reactivate.
I believe this should refresh the signal going to the Mini box. Worth a try.
