1
This discussion topic has been answered Discussion topic: No satellite
This message was authored by: Steven106
No satellite
I came in home today and put the TV on only to find that it was not getting the signal and I had not picture.  I have gone over everything but made no change..
Re: No satellite
@Steven106
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Re: No satellite
@Steven106
