Discussion topic: No satellite message
This message was authored by: J93789
Sky Tv not working
Re: No satellite message
@J93789
Very little info to go on apart from your thread title so if a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
