Discussion topic: No satelite signal
This message was authored by: Bonnie123
No satelite signal
No satalite signal
Re: No satelite signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Bonnie123
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
