Discussion topic: No satalite signal
Message posted on 29 Jan 2025 01:38 PM
No satalite signal
I have all my apps catch up is working can't get any channels
Message posted on 29 Jan 2025 01:49 PM
Re: No satalite signal
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
