Discussion topic: No satalight signal
Message posted on 05 Jan 2026 08:19 PM
No satalight signal
It's say there is a problem with my satelight signal. I've tried switching off and on. But it keeps saying no satelight signal
Message posted on 05 Jan 2026 08:21 PM
Re: No satalight signal
Rebooting won't help. With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind, rain or snow can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
