Discussion topic: No remote
This message was authored by: ClaireK70
No remote
I had a new Sky Q box delivered yesterday. My husband didn't hand over the remote - therefore I didn't get the new remote. I therefore have a box I can't connect.
I can't get through passed automated chat/phone to explain.
Any ideas?
Re: No remote
Any ideas?
hi @ClaireK70
You shouldn't need the new remote and should be able to pair your old remote to your replacement box.
May I suggest you try a reset of your old remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Avatar for ClaireK70
Re: No remote
When I connect the new box the first instruction is to go to settings (in order to link to wifi) or cancel. The old remote won't work to click on settings.
I tried 1 &3 to link the remote
Re: No remote
hi @ClaireK70
Have you reset the remote pressing 7 & 9 together as detailed above ?
Edit: As mentioned above once reset you will need to make sure the remote has line of sight of the box until it is paired
Re: No remote
I will try that when I get home. Thank you
Re: No remote
No, that still didn't work.
Re: No remote
That's very unusual. Did you hold those two buttons down long enough? Basically all remotes are the same. If this one isn't resetting and pairing, then a new one will likely have the same problem. Also it uses IR for part of this process so you have to have clear line of sight to the box
