Discussion topic: No picture......
This message was authored by: JW3TV
No picture......
One of our mini boxes will only show a picture for a second when it turns on, then the screen goes blank.
I've tried different hdmi cables, and all other configurations of hdmi ports on the tv, I've tested the cables with an Xbox, and the only issue I can narrow it down to is with the box itself.
Has anyone experienced this before, and how did you fix it??
Re: No picture......
Hi @JW3TV
Try a Network reset on the problem mini.
Does the menu show up?
