1
This discussion topic has been answered Discussion topic: No network connection
This message was authored by: GBebb
When I turn the TV on there is no network connection, sometimes the connection is lost watching programs. I have to keep pressing the WPS ?button on the Q Box to get the Connection back
Re: No network connection
Hi @GBebb
Try completly resetting the connection.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Hi @GBebb
