Discussion topic: No network connection on tv
Message posted on 20 Sep 2023 12:16 PM
Message posted on 20 Sep 2023 12:22 PM
Re: No network connection on tv
Hi @IAINPINDER
Assume this is your main Q box.
Have you tried a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 20 Sep 2023 12:29 PM
I still have no cobnection on my tv
Message posted on 20 Sep 2023 12:42 PM
@Nugget wrote:I still have no cobnection on my tv
You'll need to give some more details...
