Discussion topic: No ip address obtained
This message was authored by: tallan
Re: No ip address obtained
I had the same problem.
Read through all the threads including this one.
Tried nearly everything and couldn't understand why my broadband router was allocating Ip address 0.0.0.0.
Then just as a guess, swapped around the ends of my ethernet cable !
Even though both go in, I now had the yellow one going into the yellow port of my router.
Worked a treat so thought I would share, in case anyone else is struggling.
So hope it helps someone out there, good luck !
