Discussion topic: No internet connection
This message was authored by: Paula+Louise
Apparently I don't have internet connection on my skyq box.  It keeps telling me to press and hold a button on my router which I've done lots of times and nothing changes. Has anyone else had this problem and been able to solve it without calling an engineer
Re: No internet connection
Hi @Paula+Louise
Are you carrying out a Network reset on your Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
