Discussion topic: No internet connection since power cut
Message posted on 11 Jul 2024 06:36 PM
We had a short power cut last week and since that point I can't get my Sky Q box to reconnect to the broadband. I've got a wired connection into the box and that doesn't work. If I disconnect it and try to connect to the WiFi this also doesn't work. No other devices appear to have an issue since the power cut and my WiFi is otherwise working.
Message posted on 11 Jul 2024 06:44 PM
Re: No internet connection since power cut
I should add that I've tried resetting the box and the WiFi on countless occasions. I've reached the end of the online support guide.
Message posted on 11 Jul 2024 06:48 PM
Hi @IanCur
When main Q box is connected by Ethernet you can then switch off all Q box WiFi provided you have no minis on WiFi
On the main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
If you no minis as soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
If you have minis are they are all on Ethernet then carry out a network reset on all minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for them to connect.
Once it is connected go immediately into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
If you do have any minis on WiFi then carry out the network reset on the main Q box as above but leave WiFi on all Q boxes
Message posted on 11 Jul 2024 09:08 PM
Thank you. I have just tried this but it falls at the first hurdle of not connecting to ethernet. Searches for a while and comes back with No IP address obtained.
Message posted on 11 Jul 2024 09:26 PM - last edited: 11 Jul 2024 09:34 PM
Hi @IanCur
Is this when you carry out the Network reset on the main Q box?
If so and you haven't carried out any WPS are you sure the Ethernet cable is OK.
Edit
Wait until the router is completely back and running and then try the Network reset again.
