Discussion topic: No internet connection on sky Q box .
This message was authored by: Adcam68
Hi , we have NO intenet connection to sky Q box but have to other devices, this also means no multi room use either, is our sky Q box broken? Thanks
This message was authored by: Mr+Flibbles+86
Re: No internet connection on sky Q box .
This message was authored by: idol+the+bear
If you have a Sky router press the reset button on the back of the router and then do a search for your network on the Q box and it should appear to connect to.
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
