Discussion topic: No connection
This message was authored by: Robjack26
No connection
I can't connect mini boxes to main sky box and when it does it shuts down straight away
Re: No connection
Hi @Robjack26 in th following order:- Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
