3
This discussion topic has been answered Discussion topic: No connection with wifi
This message was authored by: Need1
Hi, I've moved been sent new router, had sky out fit dish etc... sky q only works WiFi with direct cable both only 10ft away in same room will not work without cable no connection doing the WPS way. My sky mini will not connect at all to WiFi using the WPS and to far away to use a cable. Any thoughts??
Avatar for Need1
This message was authored by: Need1 Answer
Re: No connection with wifi
Magic thank you I will try tomorrow after work and let you know. 👍🏻👍🏻👍🏻
Hi @Need1
Do you have the new Sky Max white fibre router
Hi @Need1
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
With the Sky Max router minis must connect to the main Q box by WPS (they will not connect to the Max router)
Avatar for Need1
