Discussion topic: No connection to sky Q box error message MR104
Message posted on 23 Jun 2023 07:33 PM
Error message MR104
Message posted on 23 Jun 2023 07:37 PM
Re: No connection to sky Q box error message MR104
Taken from here:
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-Q-and-Glass/ba-p/4017045
Multi room q box showing error MR104 means your mini box might be a bit too far from the main box to get a reliable signal from it.
Try going to Settings, then Setup - Network - Reset, and at step 2 of 4 on screen, press the WPS button on the front of the main box.
Message posted on 26 May 2024 11:44 PM
**bleep**. Multiroom is right on the other side of the wall.
This is a constant issue in the last few weeks.
Message posted on 27 May 2024 11:09 AM
@Gav13 the multiroom box is right on the other side of the wall is what is it the router or the main Q box and who is your internet provider
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
