Discussion topic: No catch up
Message posted on 24 Nov 2024 09:22 PM
No catch up
How do I find my password / PIN for wireless connection ?
Message posted on 24 Nov 2024 10:24 PM
Re: No catch up
Are you trying to connect your Sky Q box to your Wifi, if so the network key is usually printed on your broadband hub if you are a Sky Broadband customer.
Message posted on 24 Nov 2024 10:37 PM
Re: No catch up
And if you're on Sky broadband you don't need it, you just use the WPS button.
Message posted on 25 Nov 2024 08:06 AM
Re: No catch up
Where is this and what do I do with it ?
Message posted on 26 Nov 2024 06:58 AM
Re: No catch up
Tell the Q box you want to connect to the router by resetting the network connection through the menu
press the wps button (has two arrows in a circle) on the router when prompted, for a couple of seconds.
