Discussion topic: No Satellite signal
This message was authored by: GillR1
No Satellite signal
We have turned on the Sky Q box and are getting the no satellite signal error. We can't load the TV guide because of this error. We can get Netflix but nothing else.
Re: No Satellite signal
@GillR1
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
