Discussion topic: No Satellite Signal
Message posted on 22 May 2025 06:30 PM
No Satellite Signal
We have Sky Q, full optic fibre broadband, router is working fine & we have full wifi but cannot get TV guide or channels no satellite signal is displayed.
followed all instructions to reset & troubleshoot, it has bin playing up since the major outage last week so have bin using the firestick & trying to reset skyQ everyday to no avail. Any other suggestions? Tried to call sky but unable to get through to speak to someone.
Message posted on 22 May 2025 06:31 PM
Re: No Satellite Signal
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
