Discussion topic: No/Poor Satelite Signal
This message was authored by: Sue.w
Anybody had problems with Sky signal reception during the very hot weather - I lost reception on all Sky Channels.
Re: No/Poor Satelite Signal
hi @Sue.w
Hot weather in itself should not cause any signal problems.
However, please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Avatar for Sue.w
Now the temperatures have dropped where I live the signal has returned.  I assume the dish was distorted by the extremely hot temps moving it out of alignment.
This message was authored by: mr.tickle
Ok, but it's still worth getting it checked for next time - we will have many more heat waves (sadly).
A properly working aligned dish does not move, or lose signal, in hot weather. Very heavy thunder/snow storms are the achilles' heels, not heat.
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
Avatar for Sue.w
Thanks for replies.  Signal is still breaking up.  Engineer booked.
@Sue.w
Also check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight.
