Discussion topic: Newbie here, trying to connrct Sky Q.
This message was authored by: Jan136
Hi newbie here, tech dinosaur.  Trying to connect to Sky Q. Tells me im connected.  Does a status check, then gives me a QR code. Hub is up and running....confused...
Any help would be fab.
Re: Newbie here, trying to connrct Sky Q.
Hi @Jan136   It would help if you told us what you are trying to connect to Sky Q. Normally the installer does this for you, has something changed?
Sky Q setup doesn't display a QR code afaik. Some of the apps do and some TVs probably do.
Are you sure you have Sky Q and not Sky Stream? Do you have a satellite dish?
