Discussion topic: New uhd box
This message was authored by: DebT1
New uhd box
Just got new uhd box. Have added same card. Where are my recordings from previous hd box
Re: New uhd box
They're gone. Recordings can't be transferred to a new box.
Avatar for DebT1
Re: New uhd box
Can I use the old box?
Re: New uhd box
You are returning it to Sky...?
This message was authored by: Invisiblename
Re: New uhd box
How have you still got your "old box"?  Or is it a Sky HD+ Box?
I am just another Sky customer!
Avatar for DebT1
Re: New uhd box
Yes old sky hd box has been replaced with sky uhd box. I still have the old box at present
Re: New uhd box
So you have switched from Sky+HD to Sky Q? If that's the case then the Sky+HD Box is yours and won't need returning to Sky. However, it's of little use to you and you can't access the recordings on it.
It's only real use to anyone is as a Freesat Box connected to a dish that hasn't been converted for Sky Q.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: New uhd box
You can re-download Sky Store purchases though
