2
This discussion topic has been answered Discussion topic: New sky q mini set up
This message was authored by: Betty85
Got replacement mini box plugged in connectec to internet. Screen stuck on Accessibility on Sky Q followed by 2 options which are Settings or Skip & Set up later. Remote control appears to be working fine but wont activate either option.
Avatar for Betty85
This message was authored by: Betty85 Answer
Re: New sky q mini set up
Thank you got sorted today. All now working perfectly. Happy Christmas
Hi @Betty85
Reset your mini remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to get the accessible screen
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair
Avatar for Betty85
