Discussion topic: New sky Q main box still doesn’t record scheduled programs
Message posted on 15 Mar 2025 12:42 PM
Our sky a box wasn't recording programs we had scheduled to be recorded so sky came and replaced the box and nothing has changed, it shows being scheduled for a period and then cancelles the recording on its own.
Message posted on 15 Mar 2025 12:46 PM
Re: New sky Q main box still doesn’t record scheduled programs
Can anyone help me
Message posted on 15 Mar 2025 12:56 PM
@Kevin196
First thing to try is a reboot of the box. Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 15 Mar 2025 08:13 PM
Is this all scheduled recordings or particular ones?
