Discussion topic: New router won’t connect to sky Q box
Message posted on 26 Jul 2025 07:53 PM
Had the new router for a few weeks,
I had to reconnect once but today it won't connect.
i have switched off everything and tried to connect via was button.
Sky box flashes.. router flashes but they don't connect.
equipment less than a metre apart.
Message posted on 26 Jul 2025 08:24 PM
Re: New router won’t connect to sky Q box
Hi @GoBenton52 Is this Sky broadband? What happens if you select the SSID and input the password?
Message posted on 26 Jul 2025 09:29 PM
Hi @GoBenton52
If you have the latest Sky Max router then you need to connect it to to your Q box as if it is a 3rd party router.
This means you need to connect it to your Q box as follows.
First reset your broadband router by holding the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
As the max router is like 3rd party broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 26 Jul 2025 11:23 PM
Less than a metre? Use ethernet
