Discussion topic: New WIFI
This message was authored by: 1Oakfield
New WIFI
I have just has Community Fibre installed and all devices are connecting to the new WIFI apart from the TV. I have a main box and a mini but they connect to the network but keep dropping connection. Any ideas why?
Re: New WIFI
Hi @1Oakfield
Assume you have carried out a Network reset on the main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Also best to also carry out a Network reset onthe mini.
Avatar for 1Oakfield
Re: New WIFI
Thanks for your reply and yes I have done all of the above (many times!!) and it connects to the wifi but then drops either straight away or a few hours later. I have strong  wifi signal so no idea why??
Re: New WIFI
Use ethernet or powerlines if possible.
I assume you mean the connection from the Q box - is the TV connection itself ok, assuming it also has wifi?
