Discussion topic: New Sky Q box will not link to remote
This message was authored by: TonyC1
Our Sky Q box stopped and we had a new box delivered, but no new remote.
The Sky Q box will not work with the old remote.
We have tried linking the old remote to the new box but nothing works.
Re: New Sky Q box will not link to remote
hi @TonyC1
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
