Discussion topic: Network/ connectivity issues
This message was authored by: Gaz+j46
I'm having trouble connecting my sky q box and subsequently 3 mini boxes to my zen broadband network which uses a Fritz hub
Re: Network/ connectivity issues
Hi @Gaz+j46
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
