Discussion topic: Netflix
Message posted on 05 Aug 2025 05:58 PM
Netflix
A Netflix not working just keeps buffering can't watch anything on Netflix
Message posted on 05 Aug 2025 08:06 PM
Re: Netflix
@Bellareeves Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 06 Aug 2025 03:44 PM
Re: Netflix
Not a fix, but a potential workaround... If you have a smart TV or some other device attached to the TV that also has the Netflix app, I found they worked better for me than using the Netflix app on the Sky box. The app on the Sky box gives me juddering issues, but logging in to Netflix via another device or the TV's built-in app works fine for me.
Sky Q, Sky Full Fibre 2.5 Gigafast+ with Sky XER10 (white cylindrical Gigafast+ Hub)
