Discussion topic: Netflix
This message was authored by: Jason1334
Netflix
Hi I have Netflix as part of ,y sky package , but when I sign in on another device it says welcome and add a package to finish set up , I am using the same log in details as I did with the app on sky q box , but if I log in on another device it says I have no package and to go to netflix.com to add a package , Netflix works fine on sky q but no joy using it on any other device , any help would be greatfull thanks
Re: Netflix
Hi @Jason1334
If you subscribed to Netflix through Sky originally and have never used Netflix on any other devices;  then you possibly haven't set up a Netflix password.
The Netflix Account Email is likely to be the same as your Sky login.  This can be confirmed in the Netflix Get help menu .  (Scroll down to the bottom of the Netflix left hand menu and then scroll right to Get help)
As regards a Netflix password you can set one up in the following link
https://help.netflix.com/en/node/365
Also bear in mind the number of simultaneous screens in use.
Assuming you subscribe through Sky
Sky Ultimate TV includes the Netflix Basic plan (1 screen + SD)
You can upgrade to Netflix Standard (2 screens + HD) by adding the HD pack On Sky Q.
You can upgrade to Netflix Premium (4 screens + UHD/HDR) by adding the Ultra HD pack (requires the HD pack first) on Sky Q.
Avatar for Jason1334
Re: Netflix
I already had a netflix account before I changed to netflix with sky , thry said it would be linked to my existing netflix account which worked for a while now for some strange reason the account that sky linked now says I have no streaming plan it says this on any device apart from the sky q box I've signed in on a few devices and it says the same thing that I need to add a plan , and I am trying these devices one at a time thanks
