Discussion topic: Netflix won’t load
This message was authored by: Pauls13
Netflix won’t load
Can't load Netflix on my tv, I gave rebooted my router and re started my sky box. Netflix doesn't work, been having problems for a few weeks now
Re: Netflix won’t load
Hi @Pauls13
