4
This discussion topic has been answered Discussion topic: Netflix two devices
This message was authored by: mixedup
Netflix two devices
I have two Netflix devices available on my Sky account - TV and laptop.  Can anybody please advise if it's OK to use two different laptops provided they're not being used at the same time.
This message was authored by: PandJ2020 Answer
Re: Netflix two devices
Yes, that's fine.
Screen concurrency depends on your subscription.
Base subscription is 1 screen.   HD pack makes it 2 and UHD pack makes it 4.
These are the number of concurrent streams - which can be any compatible device.
Of course, these devices must be in your 'household' as sharing the password to others is forbidden and NetFlix are starting to track this.
Avatar for mixedup
Yes - I have the HD pack so two devices.  I was aware that Netflix are tracking, hence my question.  I wouldn't be logging in from another location but maybe watching downloaded material at another location on a third device.  My question was really if it's ok to use three devices at the same location provided there are not more than two logged in at the same time
Yes, that's fine.
Avatar for mixedup
Thank you so much
