Discussion topic: Netflix sound quality
Message posted on 28 Mar 2026 12:11 PM
Netflix Basic through Sky Q only outputs stereo
Paramount outputs Dolby surround
Disney outputs Dolby surround
HBO outputs stereo
All apps played through the sky Q box.
Could this be a faulty box?
Message posted on 28 Mar 2026 12:25 PM - last edited: 28 Mar 2026 12:26 PM
Re: Netflix sound quality
HBO outputs stereo
hi @BIGGS666
it will not be a faulty box if some apps are giving 5.1 sound (or Atmos)
I am not aware if Netflix Basic only provides 2.0 sound but higher tiers definitely should provide up to 5.1 via the SKY Q app (to get Atmos you need the premium tier and use the app elsewhere)
The HBO Max app on SKY Q is known to be currently limited to 2.0 & this has been reported back - no info yet on when this will get 5.1/Atmos (it does on SKY stream & other devices)
Do you have any other device (TV app maybe) that you can try Netflix ?
BTW Personally I use apps on a Firestick rather than my SKY Q boxes, as SKY apps are really more for convenience & SKY Q is now old in tech terms .
We generally recommend using apps on newer hardware (Apple TV boxes, Firesticks, TVs inbuilt apps) which may provide better quality (including Dolby Vision and Atmos - when applicable - on all apps rather than some)
Message posted on 28 Mar 2026 12:30 PM
Just wondered whether the stereo output was correct for basic, thanks.
Message posted on 28 Mar 2026 12:35 PM
Message posted on 31 Mar 2026 05:49 PM
Simple question but as yet no suitable answer.
Message posted on 31 Mar 2026 11:13 PM - last edited: 31 Mar 2026 11:17 PM
@BIGGS666 wrote:Just wondered whether the stereo output was correct for basic, thanks.
Why did you ask if it was a faulty box then? You might have to ask Netflix as it's their app / code. They're most likely to have a definitive answer.
