Discussion topic: Netflix not working
This message was authored by: Paul250378
Netflix not working
Hi my Netflix is not working again in my bedroom box !!
Re: Netflix not working
Hi @Paul250378
I have removed your other post as there is no need to post twice on the same issue.
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue first  try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
