Discussion topic: Netflix not working
This message was authored by: MTBlair
Netflix not working
Netflix will not load on my sky min box but works ok on my main box
This message was authored by: Kal2001
Re: Netflix not working
@MTBlair
You need to refresh the apps on the mini box. To do that follow these steps.
Press Home>Highlight Settings>Press 001 and click the center button>Click on apps> Click on refresh apps and confirm.
The message that pops up on the screen should be "Your apps are being refreshed"
Once it says that, try reloading Netflix and see if it works for you.
@MTBlair are you just getting the spinning circle ?
