Discussion topic: Netflix not loading on main box
Message posted on 06 Jun 2023 09:19 PM
Netflix will not load on main box, been like it for 2 weeks. Tried the unplug and restart
Message posted on 06 Jun 2023 09:27 PM
Re: Netflix not loading on main box
Try a Reset Settings in the main Q box hidden menu.
