3
This discussion topic has been answered Discussion topic: Need new tv codes
This message was authored by: Jg0905
Need new tv codes
The channel 5 stations have gone from sky q box in Ireland and I need the new TV codes to tune the stations back in again
This message was authored by: xenon81 Answer
Re: Need new tv codes
The Channel 5 transponder has switched from DVB-S to DVB-S2 but otherwise it's the same details as before.
Delete the current versions of C5 from your list first then tune to
11305 H
SR 27.5
FEC 2/3
DVB-S2
8PSK
11305 H
SR 27.5
FEC 2/3
DVB-S2
8PSK
Avatar for Jg0905
I did I also tried 11307 and 11306 but all that comes up is the cartoon channels that's why I was wondering if they changed codes again
No, if you're only seeing the Nickelodeon channels then you haven't deleted the Channel 5 channels from your list. You need to do that first, or they won't show up as the box thinks they're already stored.
