Discussion topic: Need engineer to replace broken cables
This message was authored by: Matthew117
On TV Settings it says no satellite signal, but my Internet works over the broadband? 2 sky tvs stopped altogether working g
Re: Need engineer to replace broken cables
Hi @Matthew117   Have you checked the cables going in to your Sky Q Main box are correctly inserted? No Satellite Signal Help.
The thread title says there are 'broken cables'?
Is there?  How?
This message was authored by: Invisiblename
@Matthew117  Unless you can see physical damage to the dish cables, or the connectors have come loose at the rear of your Sky Q box, the more likely issue will be dish alignement.  For that you will have to either call Sky and request an engineer, or get an independant in (at your own cost)
I am just another Sky customer!
