Discussion topic: Need an engineer
This message was authored by: rolo2008
Need an engineer
A builder has cut through my sky cables outside my house.  I need an engineer to rewire my service but am going round in circles online trying to book someone. How do I book an engineer to come to my house to fix the service? Many thanks for any help
Re: Need an engineer
hi @rolo2008
As this is likely to be chargeable then I think your only option is to call.
If you need a number then:
If you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
Avatar for rolo2008
Thanks @nigea99.   That is where I started my merry go round. The link takes me to suggested help topics but no phone numbers.  The My Sky app doesn't have phone numbers either that I can see (and I am VIP).   I will keep looking.
hi @rolo2008
In the link I gave you need toclick on the  '"Need More Help" to expand it & there should be a number at the bottom of the expanded section
Avatar for rolo2008
Thanks very much.  I will try that number.
