Discussion topic: Nb16
This message was authored by: Nb16
Nb16
Does anyone have a sky code for The Sero TV ?  It's annoying having to use the tv remote for turning it on and off and volume. When the sky remote should be able to do it all.
Re: Nb16
Hi @Nb16
Sky Q Bluetooth remotes (ie ones with Microphone button) does not use codes in the pairing setup.
Only Brand and Model.
In the remote pairing setup try Other Brand
This message was authored by: best+of+the+best
Re: Nb16
It's a Samsung brand have you tried Find it For me option @Nb16
Avatar for Nb16
Re: Nb16
yes I tried that as well. and it just doesnt pick up The Sero
