This discussion topic has been answered Discussion topic: NOT CONNEXTING TO HDMI
Message posted on 25 Jan 2024 09:03 PM
The box isn't connecting to HDMI
Message posted on 25 Jan 2024 09:32 PM - last edited: 25 Jan 2024 09:33 PM
Hi @Stacey3109
Switch the Q box and TV set off and then disconnect the HDMI cable at both ends.
Then refit it making sure that each end is fully located.
Then switch the TV set and Q box back on and make sure that the correct HDMI input is selected on the TV set (ie the one connected to the Q box)
Hi @Stacey3109
Message posted on 25 Jan 2024 09:36 PM
Re: NOT CONNEXTING TO HDMI
Hi this is still not working still saying fault with HSCP
Message posted on 25 Jan 2024 09:42 PM
Hi @Stacey3109
Assume that should be HDCP.
That means that the TV is having an issue with handshaking with the Q box.
I assume it has previously been working OK?
Message posted on 25 Jan 2024 09:43 PM
Yes sorry and yeah it's was installed today was working fine turned my TV off and now it's not working
Message posted on 25 Jan 2024 09:46 PM
Hi @Stacey3109
Try rebooting the Q box.
Have you got another hdmi cable you can try? Also - don't remove the cable without putting the box and TV in standby. It's not dangerous but can give a little 9V spark that isn't likely to make electronics happy.
Message posted on 02 Mar 2024 02:21 PM
I did all that but to no avail
Message posted on 03 Mar 2024 08:58 AM - last edited: 03 Mar 2024 09:01 AM
What TV is it?
edit: hang on, you're not the OP. Are you saying you have the same problem?
