Discussion topic: NO signal
This message was authored by: SGCWM
NO signal
Have tried switching off at mains and so on - no signal - light remains orange, not green
Re: NO signal
Hi @SGCWM
Try resetting your remote by holding down 7 & 9 until the led flashes 4 times, or press the power button on the box itself. You can re-pair your remote by holding down 1 & 3.
Re: NO signal
@SGCWM does the box come on if you press the orange light as that is also the on button for the box
if so it could point to your remote needing repairing which you will be able to do with you box turned on
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
